Well. Two things pop up. Either 1. He forgot to put the thermal pad on the memory and that shorted it out.
or 2. The placement of the waterblock was badly seated and did not cool the GPU properly.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/52471-7970-overheating/#findComment-702581
The outlet was blocked but he didnt realise, he means is the GPU fu****Ed?
https://linustechtips.com/topic/52471-7970-overheating/#findComment-702594
Outlet was blocked? Didn't you first run a test of the loop AND checked every connection properly? If this is true, his GPU might have just died due to the temperatures.
https://linustechtips.com/topic/52471-7970-overheating/#findComment-702603
Its complicated but it definately wasnt getting fluid
There is your first problem. Make sure the whole loop is connected and running, then check for leaks by applying paper towel under every connection and block.
https://linustechtips.com/topic/52471-7970-overheating/#findComment-702866
maybe its time for a new monitor, and i think your card is broken, you propably voided warranty, and cant RMA it. put the stock cooler back on and see if you can. trying is always an option
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/52471-7970-overheating/#findComment-707834
Hate to say it, maybe it's water damaged?
CPU: Ryzen 5 3600 @ Stock, CPU cooler: Dark Rock 4, Motherboard: MSI B450M PRO-M2 MAX, RAM: 2x8GB Crucial Ballistix DDR4 @ 3000Mhz, GPU: EVGA GTX 1080 ACX 3.0, SSD: Crucial P1 1TB M.2 + 2x120GB SSDs, Case: Corsair 110R, PSU: Corsair TX650M, OS: Windows 10 64-bit.
https://linustechtips.com/topic/52471-7970-overheating/#findComment-707843
Definitely artifacting, try it in another computer.
Is this a new card? If not, did it work before?
Higly doubt any water got on it, it worked fine before it overheated, and the systemm seems to work on a igpu
https://linustechtips.com/topic/52471-7970-overheating/#findComment-707847
