So i was wondering if this is a hard where fault or if i need a new psu, my system runs fine i'm just wondering if i need to upgrade
Welcome to the Forum!
What PSU is it?
That looks bad.
Sig under construction.
https://linustechtips.com/topic/524428-i-have-a-problem/#findComment-6961932
What exactly is the problem
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
https://linustechtips.com/topic/524428-i-have-a-problem/#findComment-6961935
Your PC wouldn't be running if those readouts were right, its just a false positive. Check the voltages in the bios, they should be correct there.
https://linustechtips.com/topic/524428-i-have-a-problem/#findComment-6961944
Voltages are waaay off.
ah
My rig:
https://linustechtips.com/topic/524428-i-have-a-problem/#findComment-6961986
that looks better
At least they're running normally enough while your PC is idling, sheesh.
An XFX TS or Antec HCG can usually be bought for cheap. Check out the PSU whitelist in my sig for good options.
https://linustechtips.com/topic/524428-i-have-a-problem/#findComment-6963869
