I know that 4 pin fans let you control the fan RPMs but my question is, is there a difference between connecting to a 3 pin chassis fan connection, a 4 pin chassis fan connection, and a 3 pin fan power connection?
3pin Chassis fan = 3pin fan power (Uses Voltage control, not as precise)
4pin = PWM (Much more precise)
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/524330-fan-connections/#findComment-6960931
If you connect 4pin/PWM fan into 3pin/DC header, you can only control it with DC. Like said, it isn't very accurate and most mobos limit it to 7V for lowest setting. Also using 3pin fan with 4pin header doesn't make fan PWM. Controlling will be same as it would when connected to 3pin header.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/524330-fan-connections/#findComment-6961129
