Good evening, and have a helthy 2016 !!
Please, I need your help!! I have a problem with a notebook monitor.
From falling down laptop, screen is flickering in many many points. You can see in the following two videos:
What do you think is the problem? Unfortunately, as you can imagine, I do not have a 2nd screen, 2nd LCD cable, etc to find what needs replacement.
From your experience, what seems to be the problem?
Thank you!
https://linustechtips.com/topic/523984-screen-lcd-cable-something-else/
Yes, something like that happened. For a period of time, if you catch with your fingers screen at the top, and you move it front-back front-back front-back etc for some times, these lines disappear for some days. And then you should do the same to disappear them again. Until that someday stopped work.
Did you drop your laptop?
QUOTE when replying to others / Quality over Quantity in your posts / Avoid ambiguous topic titles
Desktop: "Shockwave" Core i7-5820K / GTX 970 SSC / ASUS X99 Deluxe / 16GB DDR4 / 120GB Samsung 850 EVO / 2TB WD Black Caviar
Laptop:  "Archippos"  Dell XPS 15:  Core i7-7700HQ  /  GTX 1050  /  16GB DDR4  /  512GB NVMe PCI-E SSD
That's correct. Laptop is dropped.
If the screen problems started after you dropped the laptop, then it's very possible that the screen was damaged by the fall.
Yes, the screen problems started after I have dropped the laptop. But something very strange happens now.
A couple of hours ago, I achieved find a VGA monitor to connect notebook to. The one and very strange that happens is that image being in both notebook screen and VGA monitor, the notebook's screen resolution is centralized, but the image is totally clear!!! No flickers or something else.
Below I quote the notebook's monitor image when connected to the VGA monitor (green rectangle:full monitor screen - red rectangles are the lost surface from left+right):
Image loses some surface from left and right, but image is perfect. Just like laptop never drop down. How is it possible???
