I"m going to build something like this http://cdn.overclock.net/b/bb/900x900px-LL-bb49d273_20.jpeg
ordered everything, xspc photon 170.But i'm thinking should i go for a drain? what parts would i need for a Valve. or should i just go for something like this.
http://www.amazon.com/gp/product/B00J26U3R8?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A3SC7BPT5ZUZY6
It's the same case same rad position, only 1 gpu.
Valve i was planning on getting,
http://www.performance-pcs.com/alphacool-2-way-ball-valve-g1-4-chrome.html
but not sure how i would be connecting it?
Worth going for a valve more expensive ?
http://www.performance-pcs.com/bitspower-bp-mvv-dwbk-mini-valve-deluxe-white-with-black-handle.html
https://linustechtips.com/topic/523592-drain-plug/
I'd get the Bitspower valve.
Parts depend on where you put the valve. If' you're gonna put it on the reservior then just a simple male-male fitting will do. If you plan to put it  I dunno, maybe on the bottom radiator then you'll need to 2 male-male fittings and a t block.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/523592-drain-plug/#findComment-6955712
