Hi everyone,
Just re-downloaded Tasker onto my nexus 6P, and i was trying to make a profile/task which would turn the screen on with the proximity sensor, and if the display is off, then turn it off again with another wave over the sensor, but i just can't figure it out.. I've gotten the first part down, as in, when i wave over the sensor the display turns on (using the secure settings plugin), but I'm stumped when it comes to turning it off again! Any ideas/suggestions, or has anyone done it before, and can explain what they did to get it to work?
Thanks
https://linustechtips.com/topic/523555-help-with-tasker-actiontask/
