I want to wipe a hard drive through a SATA to USB cable then Import a VM from VirtualBox onto the hard drive put it back in to the computer and it should boot up normal. I think? I will be using Ubuntu so drivers should not be an issue.
Is It Possible?
Can Someone tell me how? / Link to a place where I can find out?
For more Info: http://linustechtips.com/main/topic/506093-hdmi-not-working/#entry6755769
https://linustechtips.com/topic/522476-vm-to-hard-drive/
Do you just mean a virtual box file? Dunno, it'll probably work.
https://linustechtips.com/topic/522476-vm-to-hard-drive/#findComment-6938940
