I own a  ASUS Zenfone 4. I rooted it then by mistake I reset it to factory setting. Now it is having a lot problems like Root checker is is "Sorry ! Root access is not properly installed on this devices." and my SuperSU is showing "There is no SU binary installed, and SuperSU cannot install it. There is a problem! " . I tried to install stock ROMs but its of no use. It is showing some error. And I am also not able to root it again.
https://linustechtips.com/topic/522235-rooting-problem-with-asus-zenfone-4/
Try to uninstall SuperSU and Download KingRoot from your Android browser. The app wil try too see if it can root your phone and then it will root it. After that you're set and done.
