I have recently gotten a HP network card that I'm using in my build. Problem being is that the card needs drivers that are made for Windows Servers, Am I able to still use these drivers on Windows 10 or am I out of luck?
The card is a HP NC364T Quad Port Network Card that I got for really cheap (I think it was 90% the price)
Wow this was old as heck, Need to update this signature!
https://linustechtips.com/topic/521849-drivers-for-network-card-problem/
You can allways try to install them. Windows 10 comes with support for many adapters natively. There Server 2012 drivers which you could try.
http://h20564.www2.hpe.com/hpsc/swd/public/readIndex?sp4ts.oid=5329465
Sorry for late replies
Have you tried the driver yet? If not, perhaps do, then report back.
I can't install it on your computer for you  ;)
No, I will try that now
Sweet, Lets hope it can support this card :P
So... I can't install the drivers because the card won't go in my system :D, I thought the card used a 1x slot but uses a 4x slot that's being used on my motherboard for another card lol. I think I will need a mobo upgrade already :P
Oh well, good luck  :)
You could try getting your hands on another compatible card.
 Almost as cool as my temps
Could try that, But I don't think any quad port cards can support 1x slots :/
And getting a new motherboard was the next thing I was going to do anyway lol
