Hi Guys,
I'm Running a Seidon 120V V2 cooler.
I was wondering if you can reduce the pump Rpm or would it cause an issue with  the pump?
I used msi command centre and reduced the pump to 75% which dropped it from 2339 rpm to 1905 rpm.....
I didn't see a spike in temps or anything....
Ryzen 9 7900X
Asrock X670E PG Lightning
32GB G.Skill 6000mhz DDR5
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/521732-reduce-pump-rpm/
most pumps have set RPM ratios and only the options to swap modes from "performance" to "silent"
one does not simply reduce the pump RPM with custom curves
couldnt do it with corsair link on my h100i gtx
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/521732-reduce-pump-rpm/#findComment-6928551
I know when I move the slider it reduces the voltage being sent to the pump which in turn reduces the current rpm of the pump.....
Ryzen 9 7900X
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/521732-reduce-pump-rpm/#findComment-6928560
would love if corsair link would've such a feature ... maybe i have to check my asus mobo stuff
https://linustechtips.com/topic/521732-reduce-pump-rpm/#findComment-6928677
I've been through all my mobo settings.... the whining/buzzing sound from the pump is annoying BUT if some one can tell me yes thats fine or normal then i'll be happy I dont want to using a faulty unit and one day it stops working and my nice new skylake cpu burns itself out
Ryzen 9 7900X
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/521732-reduce-pump-rpm/#findComment-6928718
