Is a WD red nessecary for a homr NAS? Or can I opt for a cheaper type of WD drive such as green?
"The ability to destroy a planet is insignificant, next to the power of the force"
Kirito (Main Build):
CPU Intel Core i5-6600k OC'd @ 4.6 GHz Motherboard ASUS Z170-AR RAM 16GB Corsair Vengeance LPX 2400 GPU ASUS STRIX 1070 Case Phanteks Enthoo Pro Storage Samsung 850 EVO 250GB, WD Green 2TB & Travelstar 1TB PSU Corsair CS550M Cooling Corsair H110i GT Keyboard Razer Blackwidow Chroma Mouse Razer Naga Epic Chroma Sound Sennheiser HD280 Pro OS Windows 10
Asuna (My Laptop): Razer Blade Stealth
CPU Intel Core i5-7200U w/ Hyperthreading RAM 8GB Hardwired into the system GPU I N T E G R A T E D   G R A P H I C S  Storage Samsung 960 EVO m.2 120GB Cooling Fans yo Keyboard Razer Blackwidow Chroma Mouse Razer Naga Epic Chroma Sound Sennheiser HD280 Pro OS Windows 10
Yui (My mini server):
TBD
https://linustechtips.com/topic/521605-home-nas-storage-options/
these are the best price / gb HHD out there and are very reliable...
Total: $82.88
Generated by PCPartPicker 2016-01-06 08:05 EST-0500
No Excuses, Play Like A Champion!!!
https://linustechtips.com/topic/521605-home-nas-storage-options/#findComment-6927037
It depends. If you're NAS is just JBOD any drive will work. If you're drive is using a RAID you will want drives optimized for that, which the WD Red's are. RAID optimized drives have some additional firmware tricks (TLER) that make them much more suited to the task. Without those firmware tweaks drives can have a tendency to randomly drop out of the array.
https://linustechtips.com/topic/521605-home-nas-storage-options/#findComment-6927343
yes, but... the additional cost for most home NASs that just hold movies, music, pics... and some other random docs... may not be worth it...
you dont need 'official' NAS or enterprise grade HHDs... will they perform better / last longer / be more reliable? probably... will most home users see any real differences? probably not...
personally i would love to have WD Red in my NAS that im actually currently building right now ... and if you can afford them great!!! but its just not worth the cost to me...
https://linustechtips.com/topic/521605-home-nas-storage-options/#findComment-6927529
~snip~
Hey there Topkek,
The short answer is NO.
NAS is considered any storage device connected to the network that is accessible over the network. For example a thumb drive connected to your router with some music that is configure to be accessible from other devices on the network or an external HDD connected to your computer and configured as a Shared Folder can also be considered a NAS.
NAS devices can work with all HDDs, regardless if they are NAS/RAID-class or not. It is recommended to use such drives, though, due to the additional features that they have (TLER and such). These features enable the drives to work much more stable and smooth with significantly lower chances of dropping out of RAID arrays or corrupting the data while in the NAS environment. This is why drives such as the WD Red are recommended for NAS setups. :)
Feel free to ask if you happen to have questions,
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/521605-home-nas-storage-options/#findComment-6927545
By 'drop out of the array' I didn't mean fail. I mean that with a normal drive if response time is slower than the controller thinks it should be then it will assume the drive is failed and kick it from the array making all that data inaccessible and requires a reboot for the controller to find it again. When the drives drop out of the array like this they also have a very serious chance of corrupting data when they do so. Drives that are optimized for RAID and have TLER enabled can essentially tell the controller 'hey i'm taking longer than normal, but I got this, give me a sec' and it will keep them in the array instead of dropping them.
A home user would absolutely notice these issues when they are having to reboot their nas all the time and their data is getting corrupted left and right. Like I said if your nas is just a JBOD, it doesn't matter because there is no array to be kicked out of. But RAID should be using RAID optimized drives.
https://linustechtips.com/topic/521605-home-nas-storage-options/#findComment-6927587
