Hi all!
For a bit now I've been looking for an Xbox 360 controller for PC, as there are some games that I can't play all that well with a controller, and after having a controller chewed by a pet I just need a new one for playing in general.
What should I go for? Normally I'd steer away from anything Razer, but the Sabertooth has really caught my eye, don't know if it'll be worth just waiting for the XB1 and using a wired controller from that or not. What do you guys think?
When you play The Game of Thrones, you win or you die...
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/
Just buy a cheap official Xbox 360 wired controller, go for the Razer Controller if you are going to be using it with both PC and console.
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-697821
You can actually use an existing 360 controller if have one if you pick up one of these USB adapters.
 http://www.newegg.com/Product/Product.aspx?Item=9SIA1PU0FK3080
Turns out to be cheaper than buying the one that is labelled "for windows" and you can get the ones with the newer black trim that way.
I originally got the Xbox 360 Controller for windows and then to play local multiplayer I picked up another regular two controllers and they worked flawlessly so I know it works.
Have fun gaming by the way. :)
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-697840
There are 2 versions of the xbox controller.
1. The standard xbox controller made for xbox
2. The same controller but made for PC
The one made for PC is more expensive for no reason at all.
Both work fine on a PC.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-697851
Just get an xbox 360 controller. They are really nice controllers, great for racing games.
Fractal Design Define S, i7 3770K @ 4.5GHz, Noctua NH-D14, Asus Sabertooth Z77, EVGA 980Ti SC+, 4x8GB Corsair Vengence 1600MHz, EVGA P2 1000W, Creative sound blaster Z, 2xSamsung 850 120GB RAID 0, 2xWestern Digital Caviar Black 1TB Other stuffs: BenQ XL2411t, LG Flatron M2262D, Ducky Shine 3, Logitech G400s, Steelseries QCK Heavy, Beyerdynamic DT770 pro 80ohm, Shure SE215, Blue Snowball
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-697960
Actually to use the standard controller you need a little dongle that you can find for cheap here.
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-699828
When I had gotten DmC and Darksiders, playing with KB + mouse was far from ideal, they felt unwieldy and a pain to use. Got sick of trying to play hack and slash games with KB + mouse, so I went and got a wired MS XBOX 360 controller for Windows and XBOX 360. What I like about it is there is no need for fiddling with mapping of keys and such, it simply works....and hack and slash games are way more fun with a controller.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-700435
Oh, i was talking about the wired versions.
Totally forgot about the wireless
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-701321
I had the Razer Onza TE and the thing was a massive waste of money. They're more expensive the 360 controllers and they're less than half the value. Unless its free I wouldn't use a Razer controller again, just get a 360 controller. Failing that, if you have a Dualshock 3 around then download Motionjoy and map it as a 360 controller, thats what I do now.
CPU: i5 2500k @ 4.6GHz (1.36V) MB: Gigabyte GA-Z68X-UD3H GPU: Palit GTX 670
Storage: 32GB SSD System OS, 2x 1TB HDD (RAID0) and 2x 2TB HDD (RAID0) Power Supply: Coolermaster Silent Pro 700W 80+ Gold
RAM: 8GB Corsair Vengeance 1600MHz Case: NZXT Phantom 410 Cooler: Corsair H100 Monitor 1: 27" Yamakasi Catleap 2560x1440 IPS Monitor 2: 23" LG W2363D 1920x1080 120Hz
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-701760
  • I know it sucks but I ended up buying a Microsoft xbox 360 controller for the PC. I started with a logictech wired rumble but that had issues with random games, then i got the logic tech wireless that had issues with different games. The xbox 360 gamepad works flawlessly with all the games that support game pads. I even use it with steam big picture just for fun some times.
Work Station:: Cooler Master Storm Trooper // i7-3930K @ 3.9 GHz // Asus Sabertooth X79 // Corsair Vengeance 16GB (4X4GB) 1600 MHz // Cooler Master 1200W Gold // Xonar Essence STX // Radeon HD 6970 // Avermedia HD Live Gamer Pro
Gaming Rig:: Cooler Master Scout // i7-2700k @ 4.0GHz // MSI Z68 // G-Skill Ripjaw 16GB (4X4EB) 1066MHz // Antec 750W Bronze // Creative Sound Blaster X-Fi HD // EVGA GTX 670
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-701816
Who says the MS XBOX 360 controller for PC and XBXO 360 suck? I'm using it and it runs on games that have controller support flawlessly, no need to set this or that profile, no need to remap this or that....it simply works.
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-701941
Sorry, What I ment was that it sucks that it cost so much, at least at the time that I bought mine. But it works, it just works. which is what i was getting at.
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-702422
I've got a wireless xbox 360 controller specifically for my PC and no problems at all.
I got it mainly for use with my astronomy telescope since I use it to slew around. Wired controllers outside in the dark are a nightmare.
Stuff I try to use;
AMD FX 8350 4.3Ghz, Asus Sabertooth 990FX R2.0 Motherboard, 2x Asus HD6850, 8BG Kingston Hyper X RAM, Hyper X 120Gb SSD, Corsair GS800 PSU, Cooler Master HAF922 Case and my branes.
https://linustechtips.com/topic/52159-xbox-360-controller-for-pc/#findComment-702595
