I woke up this morning, then slapped my PC's power button.
It turned on, all was fine, until I got into the OS, to figure that my Ethernet driver wasn't loaded, no device was detected.
So I decided to reboot the computer to fix the problem.
All the lights turned on, but it didn't post.
With further examination I noticed the power button didn't light up, unlike the motherboard and fan lights.
So I waited a while before trying again, still receiving the same problem.
Does anyone know what's wrong?
My rig:
http://pcpartpicker.com/user/Drahsid/saved/YXnXsY
https://linustechtips.com/topic/520388-rig-wont-post/
My rig:
Do you have a spare PSU laying around you could try? Had similar problems with OCZ PSU's before. If the motherboard does light up then reset CMOS or trying removing a stick of ram etc
Rig: 5950X | ROG VIII Formula | 6900XT
Laptop: 5900HX | 6800M | 16GB
https://linustechtips.com/topic/520388-rig-wont-post/#findComment-6911957
I sadly do not have a spare PSU laying around. I have already tried resetting the CMOS. That didn't work.
https://linustechtips.com/topic/520388-rig-wont-post/#findComment-6912073
