I am wanting to upgrade my PCs CPU, Motherboard and Memory.
I am looking at the 5820k but not sure which RAM and motherboard to get although I would like to keep it a white/black themed build; the Asus X99 Deluxe looked especially awesome with it's IO cover.
I had seen some Geil white Dragon memory which looks perfect but not sure if there is any other better ones.
The memory needs to comply with my Dark Rock Pro 2 cooler, so needs to have low heatsinks if any.
My budget is £600 but max £800.
Gaming PC: Case: NZXT Phantom 820 Black | PSU: XFX 750w PRO Black Edition 80Plus Gold (Platinum) | CPU: Intel Core i5 4690K | CPU Cooler: BE QUIET! Dark Rock Pro 2 | MB: ASUS Sabertooth Z97 Mark S | RAM: 24GB Kingston HyperX and Corsair Vengeance 1866MHz | GPU: MSI R9 280X 3G | SSD: Samsung 840 Evo 250GB | HDD: 9TB Total | Keyboard: K70 RGB Brown | Mouse: R.A.T MMO7
Laptop: HP Envy 15-j151sa | 1920x1080 60HZ LED | APU: AMD A10-5750M 2.5GHZ - 3.5GHZ | 8GB DDR3 1600mhz | GPU: AMD  HD 8650G + 8750M Dual Graphics | 1TB SSHD
https://linustechtips.com/topic/520323-new-build-need-help/
Here is a black & white mobo for a 2nd choice for the asus: http://www.msi.com/product/motherboard/X99S-SLI-Krait-Edition.html#hero-overview
https://linustechtips.com/topic/520323-new-build-need-help/#findComment-6911049
