So I need some help with my computer, the problem i am having is that my computer turns itself off at times when i am playing video games, i do think the problem is overheating but i have no idea really what it is.
I am wondering if I can make any improvements on my system in terms off better cooling.
I am currently using the stock cooler for the CPU.
I had a water cooler for my CPU but that doesn't work properly because it reaches very high temps for some reason.
AND I have 1 EXTRA fan for use
And also I think my CPU is lacking because i cant play GTA V(insane lag spikes).
It is a AMD FX 6100 @ 2.9 GHz, the normal speed is 3.3GHz out of box.
In the picture I have attached the CPU score from the same CPU running @ 3.6GHz compared to my CPU @ 2.9GHz
from this website  (https://www.cpubenchmark.net)
I want to be able to overclock my CPU/PC without my PC going to shit because it gets too hot.
Red circles around fans
post-63554-0-70100300-1451925647_thumb.j
https://linustechtips.com/topic/520273-cpu-help-with-clocking-and-cooling-pc/
@vegurr
Can you list your full PC spec?
@vegurr
CPU: AMD FX-6100 Six Core @ 2921 MHz (3266 MHz TURBO)
GPU: AMD RADEON HD7870 (2048 MB)
Motherboard: Gigabyte GA-970A-UD3
Power: 500W thing (tell me if its needed to know who made it or more about it)
RAM: 8GB (4 GB DDR3 KINGSTON 99U5471-020 x2)
holy mother of gpu sag  :o
Have you checked the temps while idle and at load? if they look high, that could be a reason.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
UPDATE:
When I took my pc out I removed some dust, and now i get around 30-32 degrees @ idle, and around 44-48/9 on my CPU, when playing games like mortal kombat x and GTAV.
Also GTAV works :D
But im still interested in overclocking my CPU!
and maybe get help installing a new fan, I dont know where to put it.
