OC help
Go to solution Solved by FelixM,
usually under load your temps should stay under 90°C. at least that's a major rule for me.
in terms of idle temps.... you should list the cooler you are using.
I'm using a h100i gtx and am getting idle temps around 23 degrees C, under load I am getting around 78, so I should be ok?
https://linustechtips.com/topic/520242-oc-help/#findComment-6910231
Also keep your voltage under 1.3v or your cpu dies instantly
Best Bench Runs & 24/7 Rig
Best Bench Runs
i5 4670k (XTU) - 4.7GHz Core / 4.5GHz Cache | GTX 980 (FireStrike Extreme) 1620MHz Core / 4000MHz Memory (GPUPI) 1721MHz | G.Skill Ripjaws X 2x4GB - 2200MHz CL10-11-11-24 1T
24/7 Rig & Clocks
i5 4670k 4.5GHz (Swiftech H320) | MSI Z87 MPower Max | ASUS GTX 980 1580MHz 4000MHz (NZXT Kraken X41) | 3x4GB Corsair Vengeance 1600MHz | Corsair Air 540 | EVGA Supernova G2 850w | 120GB Kingston SSD | 1TB Seagate Barracuda
https://linustechtips.com/topic/520242-oc-help/#findComment-6910316
