Do the fans will always run at their maximum speed when they are attached into the motherboard??
(Planning to install a high rpm fans on my rig, but I don't want to always run them on high speed, only when on high load work/gaming, I don't have a fan controller)
https://linustechtips.com/topic/52021-fan-question/
You can set fan curves in the bios if its supported
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/52021-fan-question/#findComment-695721
Every 3pin fan can be controlled. 2pins are for powering fan and 3rd is for rpm monitoring.
On ai suite 2 you can only control 4 pin, but via the bios you can control the 3 pin ones, makes no sense LOL
https://linustechtips.com/topic/52021-fan-question/#findComment-706452
:D didn't know that. Imo mobo manuals should have more information about controlling fans. My board has mode called silent which works only with 4pin fans but it isn't written anywhere.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/52021-fan-question/#findComment-706638
confused the crap outta me coz it said fan xpert could control em etc, get into it, doesnt work for crap LOL. went into bios, minimum fan rpms, silent modes, user defined, everything LOL.. yet ai suite 2 doesnt :/ makes no sense lol
https://linustechtips.com/topic/52021-fan-question/#findComment-706653
