Fan controller help
Go to solution Solved by Octavialicious,
Solution was found by messing with things, thanks!
Hey all, my noctua's are running loudly so I'm trying to fix my fan controller setup. I'm using this http://www.amazon.com/Kingwin-Channel-Multi-Fan-Controller-FPX-001/dp/B00DP9WRZY/ref=sr_1_4?s=pc&ie=UTF8&qid=1451825949&sr=1-4&keywords=kingwin+fan but I'm pretty sure the electric current is unstable. The Noctua's when cranked down a bunch will run, and then they will randomly stop. Again, pretty sure bad power delivery is to blame
Anyways, what would you guys recommend? I was thinking of getting a hub, and then plugging the hub into another manual fan controller and run those all at very low RPM's. Big bonus points if it is on amazon/has prime :)
Thanks! Not looking to spend much over $20, maybe $25.
Hm, very impressed with the noctuas. Did some messing with the splitters and these things are insane. All fans have both the low noise and high noise adapters attached, and if that wasn't insane enough, the voltage is heavily lowered with a manual fan controller. Wow. The quality is stupendous :D
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/519436-fan-controller-help/
