My internet speed on my pc is 60mbps download and 12mbps upload but steam only ever downloads games at a maximum speed of 10mpbs.. why?
cause steam doesn't use your full bandwidth
also...do a speedtest to be sure you are getting that speed
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/518743-internet-speed/#findComment-6893308
Why wouldn't steam use your full bandwidth?  I've downloaded from Steam fully saturating my 1Gbps internet.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/518743-internet-speed/#findComment-6893317
so if i upgraded the connection to say 100mpbs it would use more? cause i can i have 150mpbs download in the office i just have a crummy solution to it at the moment. yeah that is from a speedtest
https://linustechtips.com/topic/518743-internet-speed/#findComment-6893318
