friend of my wants a 300 euro pc which is capabel to play minecraft
his father should be able to get the os for free so that is not a problem
i made this
note there is no case but the case is not available in pcpartpicker
total cost is around 330 euro
another site which makes pc's is this one
which one is better?
tnx
hakuna matata
https://linustechtips.com/topic/518722-help-on-350-dollar-pc/
More cores for a similar pricing.
(http://pcpartpicker.com/part/amd-cpu-fd6300wmhkbox)
APU At this price point i would say
yeah if this had integrated graphics
i also think about upgrading in the long run (better cpu (you got the low end now))
hakuna matata
https://linustechtips.com/topic/518722-help-on-350-dollar-pc/#findComment-6893142
I would say this is a good build, but maybe get a cheap GPU like a GT 730 because it will outperform the CPU's integrated graphics. Plus it takes all the stress off the CPU for everything therefore making the PC faster in general tasks too. Also does he have a case already? Good luck :)
IT Manager working in the Education sector.
https://linustechtips.com/topic/518722-help-on-350-dollar-pc/#findComment-6893303
If you can put just a little more money to the cpu(maybe by not going with an ssd) go with this.http://www.amazon.com/dp/B015VPX2EO/ref=psdc_229189_t1_B015VPX3G6
With that and a dedicated gpu later down the line it should run alot more than minecraft.
https://linustechtips.com/topic/518722-help-on-350-dollar-pc/#findComment-6893411
tnx he has not but i cant find the one i am going to use in partpicker  :)
thoughed he was able to get something more powerfull along the way when he is going to play more intensive games
hakuna matata
https://linustechtips.com/topic/518722-help-on-350-dollar-pc/#findComment-6893547
Cool, sounds like a solid build then. But decide on the Case soon and what will be best for his needs later on.
https://linustechtips.com/topic/518722-help-on-350-dollar-pc/#findComment-6893818
