snip
Calibrate what?  Let me guess, you read or heard someone online mentioning "monitor calibration" and thought you needed it.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
https://linustechtips.com/topic/518282-calibrating-help/#findComment-6888492
I have a 34 inch Samsung curved monitor-S34E790C and i need to calibrate it. I am using a a titan x in case that helps, I would like to know what settings to adjust to exactly what for the best image.
Roll over image to zoom in
you need a calibarating tool (physical )for a 100% sRGB rating but windows has a tool for if you want to do it by eye
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/518282-calibrating-help/#findComment-6888570
the monitor doesent look good at all the colors are washed out
Post a photo.
Most likely your brightness, contrast, gamma settings are off.  Try using the physical buttons on the monitor to change these settings.
https://linustechtips.com/topic/518282-calibrating-help/#findComment-6888819
