Need to change the cooler all together or change the case.
  • Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler and Corsair 100R ATX Mid Tower Case are not compatible.
Part List Price History (Excluding Tax and Com
CPU: I7 5960X @4612 MHZ/1.325Vcore | Cooler: Full custom loop | Mobo: Asus X-99A | GPU: 2 EVGA 980 TI Classifieds | RAM: G.Skill Trident Z 32 GBs 3200 MHZ | Storage: Samsung SM951 512 GB M.2 Drive, Mushkin Eco2 512 GB SSD, Muskin Chronos 480 GB SSD | PSU: Corsair HX 1000i | Case: Fractal define R5 | Monitor: LG 34UC87M-B
https://linustechtips.com/topic/518190-first-custom-build-help/#findComment-6887317
Here is what I'd do:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($199.88 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($19.50 @ Micro Center)
Motherboard: ASRock Z170M Pro4S Micro ATX LGA1151 Motherboard  ($79.99 @ Amazon)
Memory: G.Skill NT Series 8GB (2 x 4GB) DDR4-2400 Memory  ($43.99 @ Newegg)
Storage: Crucial BX200 240GB 2.5" Solid State Drive  ($64.88 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.88 @ OutletPC)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($193.98 @ Newegg)
Case: Fractal Design FD-CA-CORE-3300-BL ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $754.08
Generated by PCPartPicker 2016-01-01 15:20 EST-0500
It's a little more expensive, but worth it.
-240GB SSD from a great OEM. That Kingston one is crap and has a bad history (false advertising)
-swapped memory out for faster and cheaper. Dual channel is also better here as it still leaves slots open for future expansion
-swapped GPU out for a cheaper one. Similar performance, moderate cost savings. The PCS+ is a great cooler
-swapped case for one that fits the cooler and is a great case in general. Already has enough fans for the build preinstalled
-swapped PSU out for a good one. The Seasonic S12II is a great PSU while the CX PSU should only be used in super cheap builds if you can't afford anything decent
BTW for those who don't realize it, the idea behind this build is to OC the i5-6500 using ASrock's bios update that enables BCLK overclocking on Skylake CPUs. The "Sky OC" bios is no longer just a beta bios.
https://linustechtips.com/topic/518190-first-custom-build-help/#findComment-6887336
snip
Wait, what? An informative build refining post, stating why everything was changed for the better?
i r8 8/8 m8
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/518190-first-custom-build-help/#findComment-6887367
Here is another option if you forego the SSD (you can add one in later) and if you're willing to pay a bit more:
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($183.88 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($298.99 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($66.50 @ Newegg)
Total: $768.72
Generated by PCPartPicker 2016-01-01 15:36 EST-0500
https://linustechtips.com/topic/518190-first-custom-build-help/#findComment-6887439
Total: $768.72
I kind of want a case with a window that is pretty large, is there any case that can do that and fit the stuff in it???
https://linustechtips.com/topic/518190-first-custom-build-help/#findComment-6887459
Yes if you're willing to pay another $20-30 over the Core and $40-50 over the N200
NZXT S340
Fractal Designs Define S w/ Window
When building I usually only go for Aesthetics last if there's room in the budget.
https://linustechtips.com/topic/518190-first-custom-build-help/#findComment-6887487
NZXT S340
what about the NZXT source 220
https://linustechtips.com/topic/518190-first-custom-build-help/#findComment-6887629
It has enough included fans, but there are no dust filters and the cable management area behind the motherboard tray is too small. I'd go for a better case if you can afford it. The Fractal Design Core 3300 is the same price and doesn't suffer those drawbacks, although there's no window. It's your choice though. Aesthetics versus practicality.
https://linustechtips.com/topic/518190-first-custom-build-help/#findComment-6887674
How about the corsair spec 02?
https://linustechtips.com/topic/518190-first-custom-build-help/#findComment-6887706
