Triple Monitor Mount
Bangflop
So I have three monitors right now but they are all on their own mounts that came with them and they do not look all that good because two of the mounts do not go up or down so my monitors are all at different levels.
My question is, what is a good triple monitor mount and or a good single monitor mount that I can buy three of?
As always, thank you for all your help :D
Edit- I should also specify that a "clip on" type of mount will not work for my desk because the back side is solid and there is about a 4mm lip to clip onto. And my monitors are 24"
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
Arctic z3 pro
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
I have this one and love it, its on sale for $80 USD
How much movement does each monitor have once they are all installed?
I am not sure the exact specifications, but it has swivel, tilt, and you can rotate it sideways whatever that is called, with plenty of space to adjust the monitors
