My hard drive has been very slow.
Do I need to get a new one?
what are the specs of your system?
Also, how long do you have the hard drive?
Rig: Thermaltake Urban S71 | MSI Z77 G45-Gaming Intel Core i5 3570K (4.4Ghz @ 1.4v) CM Hyper 212 EVO | Kingston HyperX Fury 8GB | MSI GTX 660 | Kingston 120GB SSD | Seagate 3TB HDD | EVGA 850W B2
https://linustechtips.com/topic/517111-slow-hard-drive/#findComment-6874684
install crystal disc manager and it will show you the info of you drive. also it may not be the hard drive it could be many other things.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/517111-slow-hard-drive/#findComment-6874691
try defragging your hard drive. Spinning platter hdd's store information in a not so linear way. It can sometimes store info for one program all over the disk making the needle have to move much greater distances. There are a lot of defragging softwares out there razer makes a few.
| Ryzen 9 3950X | EVGA 1200P2 | AMD 5700XT | ASUS Crosshair VIII Hero WiFi | G. Skill 4x16GB 3600Mhz CL16 F4-3600C16D-32GTZN | 2x1TB Samsung 980 Pro | Lian Li O11 Dynamic |
https://linustechtips.com/topic/517111-slow-hard-drive/#findComment-6874800
Deffraging will store the programs in a more linear fashion reducing the distance the needle has to move and making the time it takes to gather the information to run the program a lot quicker.
https://linustechtips.com/topic/517111-slow-hard-drive/#findComment-6874809
2tb segate baracuda
Like hdd's are going to be naturally slower.... i dont know what else to really say...
https://linustechtips.com/topic/517111-slow-hard-drive/#findComment-6874906
