Hi guys, i recently put together my first pc (yay!). Unfortunately I'm having some trouble with it.
First of all is my RAM. For some reason half of my RAM is hardware reserved, i've tried several sticks to no avail :(
My second problem is my motherboards onboard audio. There is this wierd scratchy crackling sound whenever i try to use my headphones with the onboard audio. This does not occur when im using an old Mbox.
And lastly, and perhaps least important, when in BIOS i cant see my CPU temps, but when im in windows they show in HWMonitor.
I thought it was the motherboard that was all messed up and traded it in for a new one, but the exact same problems occur.
My specs are:
CPU: AMD FX 6300
CPU cooler: NZXT Kraken x31
Motherboard: Msi 970 gaming
GPU: HD 7950
RAM: 8gb Hyperx Fury 1866hz (borrowed a matching pair from a friend, was exactly the same)
PSU: Corsair rm750
SSD: Samsung 850 evo, 120gb
Case: NZXT s340
Any help or input will be appreciated
btw go easy on me, im new to this forum :)
https://linustechtips.com/topic/516755-first-build-acting-up/
"First build acting up"
Give it an oscar. hehehehehe, anyway, the RAM. I unfortunately have no clue, maybe you've accidentally reserved some, tried googling this problem? With the onboard audio, some motherboards just don't have good onboard audio and therefore you'll hear that static, crackling noise. Not much of a fix for that. For the CPU you could just get an app to let you see your temps? I recommend MSI Afterburner, just follow a guide or go into the settings and untick all the things you don't want to be displayed and only leave GPU Temps, CPU Temps, CPU usage ETC ETC ETC.
https://linustechtips.com/topic/516755-first-build-acting-up/#findComment-6870531
Use the audio-jacks in the back I/O, not the front, the front ones are terrible
also try to use a different DIMM-slot for that ram
if nothing does it for you - maybe it's time to send it back or something.
Motherboards shouldn't have these issues these days.
Hope I could help :)
Happy for your first build bro - have fun with it! :)
CPU: Pentium G3258 @ 3.2ghz    Motherboard: Gigabyte Z97X-SLI   RAM: 1x 8GB HyperX Fury    GPU: GTS450
HDD: 250GB WD    SSD: 240GB SanDisk Now300   PSU: Old 400W Thing   Monitor: Old Samsung LCD 1680x1050
Keyboard: Perixx PX-1100   Mouse: Perixx MX3000-R   HeadphonesAudioTechnica ATH-M50X BL   Mic: Auna MIC-900BG
https://linustechtips.com/topic/516755-first-build-acting-up/#findComment-6870564
Yeah the i tried googling the problem with my RAM, tried a bunch of fixes but nothing worked. The onboard audio is not just poor it's completely unusable. I have to turn the volume all the way up in order to hear anything at all, and everything gets drowned out by the distortion.
As for the temperature, im not to concerned about that myself, just found it slightly wierd :)
https://linustechtips.com/topic/516755-first-build-acting-up/#findComment-6870570
I tried both using the front and back audio I/O. I tried every DIMM-slot, even tried using all the DIMM slots at once (my friend had the exact same pair of ram)
And thanks, i can finally play Fallout 4 B-)
https://linustechtips.com/topic/516755-first-build-acting-up/#findComment-6870587
