ears hurting after using g930 ?
No , but i haven't used this type of headset in a long time.
Other headsets and earphones i have no problem with , so i was thinking it was because of the g930 ?
I guess it could be earache, but that is usually caused by either infections or direct pressure to the eardrum, and neither seems to be the case here.
And if the pain comes regardless of sound then sound pressure is probably not the cause either.
It could be that the headset is putting pressure in the wrong places. Earache can develope if pressure is put on the jaw bone or the bone just behind the ear.
However, I have only heard of this being a possibility and i have never know anyone that has experieced this.
But I guess it's worth a shot to try adjusting the headphones. Try adjusting the headstrap a litlle and maybe try to place them a bit differently on your head.
