current system specs:
AMD a10-7700k
r7 250
16 gb 2400 mhz ram
500gb 7200 hard drive
samsung 850 evo 250gb
450 corsair psu
i need help choosing a new gpu im leaning towards a 750ti because i dont want to push my psu to hard but id love to hear someone elses opinion
p.s. im a teenager with a minimum wage job but as much as id like to have a 980ti or 390x i just cant
https://linustechtips.com/topic/516355-need-help-choosing-new-gpu/
Budget?
That PSU is really going to limit what you can get, you should have gotten something closer to 600-750W instead, and gotten 1600mhz ram instead of 2400mhz. (The speed doesn't really matter unless running an apu)
looking at your PSU
you might get away with a R7 370 if it uses one 6 pin PCI-E power plug
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
AMD a10-7701k
r7 250
16 gb 2400 mhz ram
450 corsair psu
nm....
| Ryzen 9 3950X | EVGA 1200P2 | AMD 5700XT | ASUS Crosshair VIII Hero WiFi | G. Skill 4x16GB 3600Mhz CL16 F4-3600C16D-32GTZN | 2x1TB Samsung 980 Pro | Lian Li O11 Dynamic |
below 175$
look for R7 370 which uses single PCI-E power plugs
they are more owerful than the 750Ti and closer to GTX950 power for cheaper
If you want to get a better graphics card you're most likely going to need a better psu.
Ebay.... craiglist... may be good choices to find a good gpu with that price range
