Hello, I am trying to make a good PC build for gaming and I would like some help. I already picked out most of the things that I want, but I would like some suggestions to how I could make it better or if the build is good.
Here are the Specifications:
AMD FX-6300 3.5GHz 6-Core Processor
Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard
Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
EVGA GeForce GTX 950 2GB SSC ACX 2.0 Video Card
                 This is what I have so far, if you would like to make a suggestion please, leave a comment or message me. As this is my first build, I would like to try to make it as best as I can but keep in mind that my budget is around $500.
Thank you for your time, and have a good day!
         -Darkdog51
https://linustechtips.com/topic/516339-my-first-gaming-pc-build/
That looks pretty good to me. Can't get much better for the price.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
https://linustechtips.com/topic/516339-my-first-gaming-pc-build/#findComment-6866249
this is better :)
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($107.99 @ NCIX US)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($62.98 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-2400 Memory  ($29.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Video Card: PowerColor Radeon R9 380 2GB PCS+ Video Card  ($173.98 @ Newegg)
Case: NZXT Source 210 Window ATX Mid Tower Case  ($31.99 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($24.99 @ NCIX US)
Total: $481.90
Generated by PCPartPicker 2015-12-29 23:21 EST-0500
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/516339-my-first-gaming-pc-build/#findComment-6866258
