For the longest time, running a monitor with a higher than 120hz refresh rate would cause nvidia gpus not to downclock on the desktop. I've been using NVInspector to force my 980ti to downclock when I'm not running 3D applications, but with the latest driver update, this problem seems to have gone away.
Am I crazy or did nvidia finally fix the problem?
Gaming PCs:
Intel i7 4790k, EVGA GTX 980ti, NZXT H440
Intel i5 7600k, Asus GTX 970 DC Mini, Silverstone SG13B
HTPC: AMD Phenom II X6 1045t, EVGA GTX 770 FTW, Fractal Node 604
https://linustechtips.com/topic/515206-nvidia-downclocking-issue-finally-solved/
I hope so. Running multiple 4K displays causes this problem too. Before the fans on my cards would run up but now on water it's less noticeable.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
I think it was in their release notes recently that they did fix this.  Not positive, but I swear I remember reading about it.
Meanwhile I have my cards set to "Max Performance" in NV control panel anyways :)  I hate downclocking.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
running a 1440p 144hz and never experienced this problem in the first place. But if you just recently updated your drivers and the problem went away it seems very likely it was a driver specific problem or a corrupted driver problem
CPU i7 4770k (4.5ghz OC) | CPU Cooler Swiftech H220-x | GPU 980ti G1 Gaming (1562 mhz) | Mobo EVGA z87 Stinger | RAM 16gb Kingston HyperX Beast 1866mhz | PSU EVGA 850w B-2 | Storage Seagate 2tb hdd 7200rpm(main storage) & Samsung 840 EVO 250gb (boot drive) | Case Corsair 250D
Yeah, pretty sure I read something along those lines in one of the latest drivers release. Can't remember which one was it, but I'm sure it happened.
I just wish they fixed the driver crash when opening Media Player Classic......
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
