First PC Build
Go to solution Solved by kameshss,
Here
Much more value for the price.
You have upgrade path plenty.
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  (€127.55 @ Amazon Deutschland)
Motherboard: ASRock B85 Pro4 ATX LGA1150 Motherboard  (€76.52 @ Amazon Deutschland)
Memory: Crucial Ballistix Tactical 8GB (1 x 8GB) DDR3-1600 Memory  (€39.21 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€51.45 @ Amazon Deutschland)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  (€216.31 @ Amazon Deutschland)
Case: BitFenix Comrade ATX Mid Tower Case  (€38.17 @ Amazon Deutschland)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  (€77.89 @ Amazon Deutschland)
Total: €627.10
Generated by PCPartPicker 2015-12-27 17:20 CET+0100
1. Budget & Location
My budget is 500-600 ish, and my location, as in my name Ireland :D
2. Aim
I'm aiming to use this for gaming with my friend on games such as GTA V or H1Z1 on normal settings 60fps.
3. Monitors
I still need a monitor,although that won't be included in my PC build budget, so any suggestions would be nice.
4. Peripherals
I still need a mouse and keyboard, any mouse and keyboard would do. :)
I was thinking of this PC: http://prntscr.com/9j2t2x , So I need some opinions on this.
https://linustechtips.com/topic/514217-first-pc-build/
That GPU is going to hurt :(
You may be better saving some on the CPU and grabbing a 4460 or so
What store is this?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/514217-first-pc-build/#findComment-6843357
So unbalanced wait somebody will make you a better one.
https://linustechtips.com/topic/514217-first-pc-build/#findComment-6843415
Here
Total: €627.10
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/514217-first-pc-build/#findComment-6843445
If you want more value oriented KB and Mouse, get this http://pcpartpicker.com/part/cooler-master-keyboard-sgb3010kkmf1us
If you are looking for Mechanical Keyboard, let me know.
https://linustechtips.com/topic/514217-first-pc-build/#findComment-6843467
