You guys mind giving some input on this. I want to play crysis 3/ds3 on this with high/max settings no AA at 1920x1080.
PCPartPicker part list: http://pcpartpicker.com/p/EyEk
Price breakdown by merchant: http://pcpartpicker.com/p/EyEk/by_merchant/
Benchmarks: http://pcpartpicker.com/p/EyEk/benchmarks/
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($149.99 @ Microcenter)
Motherboard: ASRock H77 Pro4/MVP ATX LGA1155 Motherboard ($87.55 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($43.98 @ Outlet PC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($73.98 @ Outlet PC)
Video Card: Gigabyte Radeon HD 7950 3GB Video Card ($297.98 @ SuperBiiz)
Case: NZXT Source 220 ATX Mid Tower Case ($49.99 @ Amazon)
Power Supply: Corsair Builder 600W 80 PLUS Bronze Certified ATX12V Power Supply ($51.98 @ Newegg)
Monitor: Asus VS238H-P 23.0" Monitor ($129.99 @ Newegg)
Total: $925.44
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-02-19 20:14 EST-0500)
https://linustechtips.com/topic/5138-need-some-input-for-rig/
I wouldn't go as far as full AA and 3D. I agree on the Seagate suggestion, but as for the performance I think if you drop the 3D and lower some AA settings it should be fine on High-Max settings with an "acceptable" FPS.
Here is a video of someones rig with the same CPU and GPU (Take into account both are OC'ed)
Intel i5 3570k @ 4.0GHz | Gigabyte GA-Z77X-D3H | Sapphire Radeon HD 7870 2GB OC GHz Edition | Corsair Vengence 8GB DDR3 @ 1600MHz
https://linustechtips.com/topic/5138-need-some-input-for-rig/#findComment-59581
7970 system under $1k http://pcpartpicker.com/p/EI3g
looks pretty good to me :)
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/5138-need-some-input-for-rig/#findComment-59595
if you wanna game, stick the money where it's most needed. the graphics card :D
https://linustechtips.com/topic/5138-need-some-input-for-rig/#findComment-59596
