X79- Custom 600T Case. Yeti v2.5.0
Gxp08
Build specs:
I7 3930k oc @4.8 (5.0 second preset) x79 chipset
16 Gig G-skill Ddr 1600(4096 X 4)
Asus X79 sabertooth Mobo
Asus Gtx 690 Gpu
Corsair H110 280mm Liquid cooler
Crosair. Ax1200i Digital Psu.
 Ssd Kingston Hyper X 240 Gig (X2 Raid 0). Ssd Patriot Wildfire 120GB.
X Fi Titanium HD Sound Card.
logitech z906
Gaming Peripherals Asus VG278H Nvidia 3D Vision Led. Logitech G710+ Keyboard. Logitech G700 Mouse
Pc Recording: Hauppauge HD Pvr 2 Gaming Ed
I Went with a vertical Mounted cooler. Added 5 Custom Painted Noctua Fans, extended Case window, Custom Ssd Mounting. Removed all front Bay Cages. Sli Gtx 780's Soon, Just need to find time to paint them.
Yeti S.a.f.c Today :
[imgur](http://i.imgur.com/iLhQ91Q)
[imgur](http://i.imgur.com/vFGW7ZE)
[imgur](http://i.imgur.com/vrYcJEt)
[imgur](http://i.imgur.com/mB94xzy)
[imgur](http://i.imgur.com/eaxtIny)
Rebuilding a Monster :
[imgur](http://i.imgur.com/3HtpErR)
[imgur](http://i.imgur.com/MEPDSe8)
[imgur](http://i.imgur.com/aapeLkR)
[imgur](http://i.imgur.com/PCv8kqG)
[imgur](http://i.imgur.com/enO8NUR)
[imgur](http://i.imgur.com/jTVcBaP)
[imgur](http://i.imgur.com/MuvKWDv)
The Tear Down:
[imgur](http://i.imgur.com/SzU8961)
[imgur](http://i.imgur.com/ZrFikqC)
[imgur](http://i.imgur.com/Rh1v8Dt)
[imgur](http://i.imgur.com/lIYikqL)
Should have just made an album on Imgur. Anyways loves the Noctua's and the way you mounted the H110 and SSD's is very different. Also why the AX1200?
I got a pretty sweet deal on it . Gtx 780's Sli, Maybe tri in the near future. I hear amd has a titan Killer cooming soon.
what voltage are you using for ur 4.8ghz and 5hz OC also how are your temps with a AIO cooler? and your ambients.
The rig looks awesome!
Is that the H110? Does it perform good? I was thinking of buying one my self.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
I will be doing benchmarks on Sat, so i will keep you posted on my new Clocks and Temp's. My cooler is H110i from Corsair (280mm Rad with a push/pull Config) It works Great, You just need to find room for it to fit.
