Every time I go on a webpage or watch a video on YouTube, a TV-Show using some software on my computer, It will freeze up and unfreeze after about five seconds and it will do that periodically unless I am just doing simple web-browsing or even on games it doesn't do that from the hours of ArmA 3 i have played since I put this in my system yesterday. My question is: Is my low-end GPU causing these problems ever since I added my 4790k in? These problems weren't occurring before and no matter what I am getting a new GPU within the next 3-4 days but, I just wanna know to be sure a new GPU will solve the issue.
Specs:
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (Purchased For $0.00)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  (Purchased For $0.00)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  (Purchased For $0.00)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory  (Purchased For $0.00)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory  ($84.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($81.49 @ OutletPC)
Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($0.00)
Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($44.75 @ Amazon)
Video Card: Sapphire R7 260X
Case: Cooler Master Storm Trooper ATX Full Tower Case  (Purchased For $0.00)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (Purchased For $0.00)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($0.00)
Case Fan: Cooler Master SickleFlow 69.7 CFM 120mm  Fan  ($4.99 @ NCIX US)
Keyboard: Razer DeathStalker Wired Gaming Keyboard  (Purchased For $0.00)
Mouse: Razer Razer Naga 2014 Wired Laser Mouse  (Purchased For $0.00)
Headphones: Razer Kraken Pro Headset  (Purchased For $0.00)
https://linustechtips.com/topic/513165-freezing-up-issues/
What is your current GPU? (The 'low end one', there's no way you are referring to the Fury X)
Have you tried a different browser?
(Don't use Internet Explorer. If you have Firefox try Chrome, or visa versa)
I assume it isn't related to your internet speed. But it could be. What's your internet speeds?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/513165-freezing-up-issues/#findComment-6836315
Internet is fine, I have 60+ mbps download and 4+ mbps upload from Charter. My current GPU is listed above, a R7 260x, a quite low-end one. I use Firefox all the time as well.
https://linustechtips.com/topic/513165-freezing-up-issues/#findComment-6836392
Ok, internet sounds fine. Your GPU should be able to handle a video, even though its a lower end one.
Try using Chrome (and update flash if you're using it, though I think it should be using HTML 5 if your computer supports it)
https://linustechtips.com/topic/513165-freezing-up-issues/#findComment-6837400
I think I may have solved the problem by enabling V-Sync on the card. It wasn't just a video issue with Youtube or anything, it was whenever I loaded a movie, or a website with pictures/ads etc,,
https://linustechtips.com/topic/513165-freezing-up-issues/#findComment-6837449
