Hello, this is my first official build, I've tried multiple times in the past and failed quite greatly, so I restarted my build and this is what I chose. Anything that isn't selected I already have. I plan on overclocking this CPU to as far as the Kraken x61 can take it. Please give me feedback on what you'd change. Post your changes below or just things I should change. I run a 1920 x 1200 monitor, and I play many high end games.
Thanks
https://linustechtips.com/topic/512893-first-pc-build/
Thanks
http://pcpartpicker.com/parts/partlist/
https://linustechtips.com/topic/512893-first-pc-build/#findComment-6831614
Use the [bB] code or the permalink to the list. That link just shows us our last edited build.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/512893-first-pc-build/#findComment-6831620
Thanks
you shouldnt buy a cpu that is cheaper than your cooler
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/512893-first-pc-build/#findComment-6831621
Thanks
That water cooling will bite you in the butt. If you get a 6700k and a hyper 212 you will get much better performance.
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/512893-first-pc-build/#findComment-6831688
https://linustechtips.com/topic/512893-first-pc-build/#findComment-6831697
