After Effects not rendering
Solved by ALwin,
OK, I think I've managed to render out the text. Don't ask me what was causing the issue because I am not 100% certain. What you need to do us unlock the layer with the text. Select it then in the menu Layer make sure Guide Layer is not checked. If you look in the two screenshots you posted, notice that there is a blue hash/pound symbol in the text layer's name your Video Transition. That indicates it is a guide layer.
A layer that is set as a guide layer normally does not get rendered.
It Works!
NOTE: with After Effects CC, start using the included Cinema 4D lite instead of Ray Traced 3D. Adobe considers RT3D obsolete for the latest versions of AE.
