I'm looking for a good gaming display. I plan to use it about 25 feet from my tower so extended cord options will be a requirement. I would like it to be 1440p 144hz ips and have g-sync. Also the smaller the better. I don't think I would be comfortable with a monitor above 25inches as my current one is 19 inches.
https://linustechtips.com/topic/512589-need-display-suggestions/
When you say 25 Feet from your tower, does that mean the monitor will be close? or do you have your pc across the room/in another room?
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/512589-need-display-suggestions/#findComment-6828346
>2k15
>forgetting about Kwanzaclaus
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/512589-need-display-suggestions/#findComment-6828350
The monitor will be 25 feet from the tower (the tower is going to have a 42" hdtv next to it and this will be at the workstation for non-video stuff/when it is too cold to be in a chair)
https://linustechtips.com/topic/512589-need-display-suggestions/#findComment-6829334
