Motherboard integrated wifi or expansion slot (which is better)
Gapi21
Hello
Im building my new computer and im wondering which is better in performance and cpu dependant pcie wifi expansion slot or motherbord integrated wifi?
USB ones work too (and are improving all the time)
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
It won't matter if the devices are otherwise similar. Dedicated cards have more often replaceable antennas and tech that utilizes multiple antennas like MiMo. But that's not always the case and it's not the fact that it's a dedicated card that making it better in performance. Think a bit bigger. Would it be beneficial for you to be able to replace the card down the line? Are you goig to be running SLI or something else that's blocking PCI-E slots from being used?
