Firstly, I am sorry if this is better of in the troubleshooting section. I just feel as if this solely is a software issue.
I own an Asus K73SV laptop which has a touchpad driven by synaptics drivers.
The problem:
  • whenever I only move the mouse with the touchpad just a little bit, e.g. 10 pixles it keeps snapping back to where it was.
  • This is very annoying and makes on screen buttons hard and frustrating to press.
  • I can't disble the synaptics driver all together since that will disable functions like 2-finger-scrolling or zooming with 2 fingers
Do you have Any ideas what I can search for or maybe even how to fix it?
I already had a look at the install folder of the driver but there didn't seemt to be any setup :/
UPDATE: I havenow found a .inf filethat might be the solution of my problem but is very hard to sort through since it is +13k lines long. Shall I post it here?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/511933-touchpad-snapping-issue/
