i got my self into a bit of a budget from spending on junk now im left with 1000usd to build a new rig i already bought a msi 980ti gpu but do not know what to pick for the other component i game on it and hope to record and edit video for fun but i do not expect much just a preference
https://linustechtips.com/topic/511895-build-help/
Hang in there, I got a build coming up. You have both a 980Ti and $1000?
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/511895-build-help/#findComment-6821552
Here you go: http://pcpartpicker.com/p/fHMfXL
https://linustechtips.com/topic/511895-build-help/#findComment-6821631
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($379.99 @ Micro Center)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($117.98 @ Newegg)
Memory: A-Data XPG Z1 16GB (2 x 8GB) DDR4-2400 Memory  ($73.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($147.99 @ NCIX US)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($59.99 @ Micro Center)
Total: $960.88
Generated by PCPartPicker 2015-12-24 11:05 EST-0500
The reason I put 850W is 550W and 850W is at same price! :)
And you can add another 980Ti in future for SLI! :)
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/511895-build-help/#findComment-6821644
