Choosing between these coolers
Hello! ^^
I'll need a cooler to cool i5-6500 with OC (yes, I can :P)
I can choose between these:
Arctic Freezer 7 Pro Rev.2
Cooler Master cooler Hyper T4
THERMALTAKE Contac 21
Deepcool "Gammaxx 300"
I think Hyper T4 is pretty good
Which one you would suggest?
https://linustechtips.com/topic/511792-choosing-between-these-coolers/
Check which cooler does NOT bend Skylake CPUs and go with it
:D
They're not that heavy comparing to noctua or mugen, so I think it'll be OK)
It's not about weight but how it's distributed.
Yep, but it's not THAT critical when the cooler is lighter)
Anyway, there is no test for every cooler on skylake and I can't know exactly how the weight is distributed until I'll buy it)
Google "Skylake bending" and check which coolers work and which dont :D
