Alright so i just finished my new which has the asus 980ti and i need a PC monitor to go with it
My budget is £500 (willing to go £600 at a push) and i want a monitor for competitive FPS gaming
I'm considering this http://www.scan.co.uk/products/24-aoc-g2460pg-144-hz-g-sync-gaming-display-displayport-1920x1080-350cdm2-80m1-1ms-usb-hub
 i don't know if i really need G-synk and i would like to eventually get 2 monitors, i'm just wondering if g-synk is pointless with a 980ti at 1080p
https://linustechtips.com/topic/511600-need-help-with-choosing/
980 ti is a pretty powerful card so if you wanted to go 1080p i would go with something like this:
https://au.pcpartpicker.com/part/aoc-monitor-g2770pf
I really think tho with all that power in your card u culd go up to 1440p and get something like this:
https://au.pcpartpicker.com/part/samsung-monitor-s34e790c
and you get more quality out of it...
What is your preffered resolution and screen size and what do you do with your pc?
https://linustechtips.com/topic/511600-need-help-with-choosing/#findComment-6818508
I game a lot and stream from time to time but I really like 120-144hz gaming and hitting over 60fps constant so really 1440p is out because most games are only getting 40-50fps from what i have seen
https://linustechtips.com/topic/511600-need-help-with-choosing/#findComment-6818527
https://au.pcpartpicker.com/part/benq-monitor-xl2720z
Maybe this would be good. Looks pretty cool too :-)
Do you have a big desk? What screen size do you prefer?
I have looked at this before and considered it but i don't know if i want to go to 27" because i have a good sized desk but 2 27" monitors take a lot of space (it would look odd getting one smaller one) its good considering its only £300 though
https://linustechtips.com/topic/511600-need-help-with-choosing/#findComment-6818627
But 1440p is perfect for that card. :(
Get a mointor like XB270HU then get an ancient crt monitor.
Corsair 760T White | Asus X99 Deluxe | Intel i7-5930k @ 4.4ghz | Corsair H110 | G.Skill Ripjawz 2400mhz | Gigabyte GTX 970 Windforce G1 Gaming (1584mhz/8000mhz) | Corsair AX 760w | Samsung 850 pro | WD Black 1TB | IceModz Sleeved Cables | IceModz RGB LED pack
https://linustechtips.com/topic/511600-need-help-with-choosing/#findComment-6818737
