Okay so i made this rig for my first ever PC
I've never had a PC before (only macs) and these MOBO and case compatibility is kind of confusing...
So I have about a 150$ left, i'm not changing any other parts
I would really appreciate it if you can find me a MOBO and a Mid tower Case near the 150$ range
The case should be red because everything else in my room is also red, but if not then a window is fine as well (red case+window = great!!!)
also decent air flow
I already have the PSU so dont worry about that
thx for the time
heres the rig: http://pcpartpicker.com/p/ryymXL
https://linustechtips.com/topic/511588-help-pls/
thx for the time
Follow your topics!
My guide to the rescue! It's in the sig, the blu link
Here I've modified your part list, and I've thrown in a boot 120GB SSD since you had so much money left over
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($98.98 @ OutletPC)
Motherboard: ASRock 970 Pro3 R2.0 ATX AM3+ Motherboard  ($56.98 @ Newegg)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($203.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($47.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($34.99 @ NCIX US)
Total: $562.88
Generated by PCPartPicker 2015-12-23 21:16 EST-0500
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/511588-help-pls/#findComment-6818381
This should work for your red theme.
PCPartPicker part list: http://pcpartpicker.com/p/9nrJJx
Price breakdown by merchant: http://pcpartpicker.com/p/9nrJJx/by_merchant/
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard  ($93.97 @ OutletPC)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($29.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Case: Thermaltake Commander MS-I Epic Edition (Black/Red) ATX Mid Tower Case  ($48.99 @ SuperBiiz)
Total: $560.88
Generated by PCPartPicker 2015-12-23 21:39 EST-0500
https://linustechtips.com/topic/511588-help-pls/#findComment-6818489
