Hey guys
okay my friends laptop can´t get into windows. when he turns it on it boots up shows the asus logo and then the screen is just black with the mouse showing and it just stays like that.
once it boot into windows fail finder or what is called but after we tried the recovery option it just stayed on 1 % and then after 10-15 minuts said recovery failed do anyone know what to do? i think it is someting with the hardrive or motherboard. as it posts but can´t get into windows.
help would be nice
Mads:)
https://linustechtips.com/topic/511315-pc-start-problems/
If it was to do with the motherboard it wouldn't post, there is potential for it to be a hard drive, do you have a pc you can test the hdd in?
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/511315-pc-start-problems/#findComment-6815427
Hey guys
help would be nice
Mads:)
Could be a failing Hard Drive as SherifsDog22 said. It could also just be a corrupted Windows install. If you have installation media for your version of Windows, boot from that. When you arrive to the screen where you have the option to select ​Install Now​, there should be another option to Repair your Computer.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/511315-pc-start-problems/#findComment-6815472
