So I'm finally getting rid of my old Fx-8350 and moving over to Intel, I'm looking at getting the 4790k and I just need a little help choosing the motherboard for it. I've heard that with the 4790k that the motherboard doesn't really effect how much of an overclock you can get although im not too sure. Also i dont really want to be spending loads on a motherboard just for it to look a little better.
Thanks guys!
CPU Intel i7-6700k | Motherboard ASUS Maximus Hero VIII | GPU MSI GTX 970 | RAM 16 GB Corsair Vengeance 3000Mhz | Cooling Noctua NH-D15 | Storage 240GB Crucial M500; 2TB Seagate Barracuda | PSU EVGA 850w | Case Phatek Enthoo Pro M Acrylic
https://linustechtips.com/topic/511220-motherboard-help/
asrock extreme 4.. ignore bandwagon "asrock suxxx!1!1!" morons.. asrock make solid boards
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6814282
Anything by Asus, Gigabyte or MSI in the higher tier will serve you well.
Go for what you like the look of.
Main Rig:-
Server:-
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6814326
Asus Z97 Ranger which I have is pretty decent, looks quite good aswell, cheaper of the RoG boards, although I wish I had got the MSI SLI Krait to match my build
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6814383
Well i know that i will eventually SLI, i want to be able to overclock my CPU as far as possible with NH-D15 without the motherboard needing to pull a silly amount of power to do so whilst keeping stable. Also the board has to also be a reliable one, i dont want things dying on it within months of purchase. Decent onboard audio would also be very nice. And thats about it if im honest.
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6815782
Apparently the Ranger has been discontinues which is a massive bummer -.-
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6815857
In that case, grab the Krait
Ryzen Ram Guide
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6815886
I'll have a quick look at that one!
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6815902
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6815933
Ryzen Ram Guide
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6815938
Ryzen Ram Guide
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6815960
What about the MSI Gaming 5?
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6823949
I'm now deciding between the Gaming 5, Sabertooth MK2, Asus Z97-A, and the Hero.
https://linustechtips.com/topic/511220-motherboard-help/#findComment-6824021
