Help with motherboard/cables!
Go to solution Solved by TheSupremeReptile,
Oh yeah, if you're cable isn't the right fit, you can pop off some of the connectors for the CPU & graphics card.
And don't worry you can pop them back to a full sized connector  :)
Hi! Im for the first time going to build a PC, or more like change parts like the PSU, GPU and the case.
I need some help with where some of the cables go, like the cable to the power button on the case.
Could i upload a pic of my motherboard?
Anyways, thank you for taking your time reading this!
And please give me some advice x3
(Sorry for being a newb 3x)
https://linustechtips.com/topic/511145-help-with-motherboardcables/
I couldnt Show you each individual cable but If you tell me the model of your power supply and motherboard I would be more than happy to find a tutorial for you :)
Also, Welcome!
most of the PSU connectors should be fairly self explanatory (just be careful of the 8 pin CPU power and any 8 pin PCIe power cables)
the front panel headers should be outlined in the manual or even on the motherboard itself and the front panel cables labled where they connect to the motherboard.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
It's not as hard as it looks, most of the ports on your motherboard are labeled, most of the cables explain themselves & if you're still having problems just look up a buildlog of Linus & watch it carefully or look at the manual.
I've recently switched out my power supply & graphics card and that was my first time ever touching the inside of a pc (excluding cleaning).
Just use your logic & common sense, don't be afraid to look things up, but whatever you do DONT PANIC!!
I panicked & it took me 4 hours before I was done so yeah.
Oh yeah, don't forget to have fun when you're building :D
Okay, im done with building my pc its all set. But. My sound does not work, graphics card, ethernet and drivers being all f'ed up. Please help me quick!
