So what are the symptoms of certain parts not working? My motherboard's LEDs are not turning on so PSU/Mobo problem? Maybe I didn't connect all the required cables to power it??
first...try the basic hardware and make sure your cables are all fully plugged in
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/510933-system-doesnt-post/#findComment-6811238
you need the 24 pin  for mobo and the 8 pin CPU power
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/510933-system-doesnt-post/#findComment-6811357
