Hey guys, this is my second post in this forum. In the first one, I recieve a lot of feedback from good people, which I really appreciate. I made some changes to my pre built.  I would like to know what you think about  it and if it is necessary to change or add more parts.
My budget is between $800 USD  and $900USD , but it would be nice to reduce it to 800$ USD or less ( if it is possible)
Thanks
P.D
- I already have a mic,a keyboard, a mouse, a keyboard, a monitor and an optical drive.
- I am majoring in software engineer and I love playing videogames ( Dota 2, CS GO, Hearthstone, Starcraft 2 , HOTS, Mortal Kombat X and more on) so i am gonna use this computer for engineer stuff and gaming.
- I am going to overlock the computer, but I dont know if the PSU is the right choice for it. Please, let me know, so I can change it
Intel Core i5-4690K 3.5GHz Quad-Core ProcessorIntel Core i5-4690K 3.5GHz Quad-Core Processor
Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler
MSI Z97-GAMING 5 ATX LGA1150 Motherboard
Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory
Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive
EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card
Corsair SPEC-03 Red ATX Mid Tower Case
EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply
https://linustechtips.com/topic/510841-my-first-built-computer-help/
i would swap the 960 for a 380. it costs the same and performs better
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
Pretty much here you go:
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150 Motherboard  ($61.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($44.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Video Card: XFX Radeon R9 290X 4GB Double Dissipation Video Card  ($293.98 @ Newegg)
Case: NZXT Source 210 (White) ATX Mid Tower Case  ($34.99 @ Amazon)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($66.50 @ Newegg)
Total: $860.41
Generated by PCPartPicker 2015-12-22 19:27 EST-0500
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
needs less cpu, more gpu, and a better psu
@RileyGav no the g1 nex series from evga suck,the b2/gs/g2 is far superior than the g1
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($28.99 @ NCIX US)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard  ($50.88 @ OutletPC)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($41.49 @ Amazon)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($66.99 @ Amazon)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($293.98 @ Newegg)
Case: Deepcool TESSERACT SW ATX Mid Tower Case  ($42.98 @ Newegg)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ NCIX US)
Total: $898.27
Generated by PCPartPicker 2015-12-22 19:30 EST-0500
The site has changed....
Total: $898.27
Don't forget GQ and P2 :D
Total: $898.27
what?
This is good though to save money the PURE ROCK and SSD aren't totally needed.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
Total: $898.27
So, should i change the PSU? I thought the one that i chose was pretty good
Yes, NEX series is only decent, but G2/GS/GQ/B2/P2 are actually good.
GQ offers great value for money, B2 too. G2 and GS are around the same as GQ in terms of quality, but they're a bit more expensive, P2 is outstanding and has 10 years warranty (the best psu you can get imo)
y
This^ also the EVGA PS
or any seasonic unit/xfx ts-xtr
Are those good for overlocking?
They're great. One of those units if 650W can support any single-GPU setup no matter how far you overclock basically.
The http://pcpartpicker.com/part/evga-power-supply-210gq0650 is well priced right now, grab it.
Total: $860.41
Thanks, but  I don't really the SSD and I am sticking to Intel i5
And, I am gonna change the PSU for the one that you recommended me
$803:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($198.75 @ OutletPC)  <<This OCs with the AsRock mobo (BCLK)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($32.50 @ Newegg)
Motherboard: ASRock Z170M Pro4S Micro ATX LGA1151 Motherboard  ($98.99 @ SuperBiiz)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($65.88 @ OutletPC)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($179.99 @ Newegg)
Case: Corsair Carbide Series 300R Windowed ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($56.99 @ Amazon)
Total: $773.08
Generated by PCPartPicker 2015-12-22 20:10 EST-0500
Note:  The EVGA GQ line is made by FSP.  I don't know how good/bad it is though.  Seems okay I guess:  http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=451
The B2 is better =P.  Not really:  http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=393
