Won't Power On
By
Piggy
in Troubleshooting
in Troubleshooting
Solved by Tsuki,
no its plugged into a picture frame
thats probably your problem then. the 12v power given to some picture frames(like those fancy ones you plug usb drives into to change the picture and shit) isnt quite enough to power your pc. consider plugging it directly into the wall and see if that resolves your issue.
Featured Topics
Cramig88 ·
Posted in Networking0 -
4
dominz88 ·
Posted in Peripherals1 -
3llyas ·
Posted in Graphics Cards1 -
jsnotlout1 ·
Posted in Graphics Cards11 -
1
Artur Hawkwing ·
Posted in Storage Devices5 -
Blazepoint5 ·
Posted in Laptops and Pre-Built Systems1 -
INotPablo ·
