I've made some changes to my build, I will buy a hard drive later when I can afford one.
Intel Skylake i5 6500 3.2 - 3.6GHz Processor
Antec VP600P 600w Power Supply
Gigabyte G1 Gaming GTX 970 4GB Graphics Card
Corsair Carbide Series 100R Mid-Tower Case
Gigabyte GA-B150M-D3H Motherboard
2x4GB Kingston HyperX FURY 2133Mhz DDR4 RAM - Black
23" AOC Ultra Slim IPS Monitor with dual HDMI
120GB Intel 535 Series 2.5" SSD 540MB Read/480MB Write
https://linustechtips.com/topic/510408-my-first-build/
Since you're low on cash, the r9 380 might be a great choice for you! It beats out the 970 in some games and vice versa. It's a very good build! That PSU bothers me tho. I would change it to something like a 80+ Gold rated PSU. Like a EVGA 750w G2.
"Audiophilia... when you start to hear voices in your head."
https://linustechtips.com/topic/510408-my-first-build/#findComment-6805361
How bout corsair rm
When lives hand you lemon, suck them hard and post a selfie with it.
https://linustechtips.com/topic/510408-my-first-build/#findComment-6805406
Skip that SSD for a faster one.
Grab a 390 for a 10% performance boost.
Switch out the PSU for a SeaSonic or XFX 650W unit.
Everything else is fine.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/510408-my-first-build/#findComment-6805421
If you're tight on cash I'd swap the build for a 4th gen platform; depending on your area, you could get much better value. Also the ssd is poor; you said they were a good deal, but still I'd only get one if you really want to, 850 evos are much better and not insanely more. Also 380 for 970 is better value.
If you make a post contradicting mine that doesn't directly address my claims, or cites 'facts' without evidence, I'm probably not going to bother responding to it, because you probably didn't bother reading my post properly, and because life is too short. It doesn't mean I don't have an answer for you. It means I'm not dignifying you with a response.
https://linustechtips.com/topic/510408-my-first-build/#findComment-6805428
Is that a typo or are you high? A 380 is comparable to a 960, not a 970.
https://linustechtips.com/topic/510408-my-first-build/#findComment-6805429
Holy Christ. You're the third person today who's typed "380" instead of "390".
https://linustechtips.com/topic/510408-my-first-build/#findComment-6805435
I meant 380 because his budget sounded tight, but 390 would be good also.
https://linustechtips.com/topic/510408-my-first-build/#findComment-6805448
The SSD is half the price of other 240gb SSDs is it worth paying the same for half the storage?
https://linustechtips.com/topic/510408-my-first-build/#findComment-6805469
Yes. The SSDNow series has extremely low random reads and writes. This really shows in typical use scenarios like opening and closing applications.
https://linustechtips.com/topic/510408-my-first-build/#findComment-6805478
It's not same price for half the storage, it's half price for the same storage at a fraction of the real world speed. I wouldn't spend as much on my 3rd to 6th terbyte as my 1st 3 cos i wouldn't use it, and I would pay more for faster storage of my most important data. It depends on your utility manifold as to what you find importnant. that's something we can't answer for you, but only note the experiences other have had with the products.
https://linustechtips.com/topic/510408-my-first-build/#findComment-6805497
