Using headphones and speakers
s1lentb0b
Hi,
I am getting into PC gaming after the past 5 years as a mac owner.
I currently have my speakers plugged into the back of my PC and I have a question.
If I want to plug in a set of headphones they have a mic and audio lead, I dont really want to have to unplug my speakers each time I want to swap to the headset.  Is there a way to easily accomplish this task?  I have seen a splitter on amazon http://www.amazon.co.uk/Konig-Audio-Headset-Loudspeaker-Switch/dp/B000WCNF2G/ref=sr_1_2?ie=UTF8&qid=1450708734&sr=8-2&keywords=pc+speaker%2Fheadphone+switch
is that the best way to go?
You can plug them into the front panel of your pc, then the speakers wil automatically be turned off and you'll receive all the audio through your headset.
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
this
granted to switch between the two you have to dig through the audio CP and change the default source every time. OR unplug the headphones every time your done... if either of those are no problem then just do what Zyntax said
We're all dying slowly
Pentium G3258 3.2 ghz / ECS z97 pk MOBO / Intel Stock Cooler / R9 290 DD / Corsair Carbide Air 240 / 4GB mushkin stealth ram at 1600 / XFX 650W 80+ gold PSU / Kingston v300 240GB drive W/300GB seagate drive / HP x2301 / Gateway KB / Monoprice GM
